my vmb400 is connected to the internet but the app or the computer doesn't see it
have done the reset and still won't see it
Hi, are you still experiencing this issue?
yes
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
