vmb3000 how do i sync the cameras
i am trying to sync the cameras, it says to press the sync unit on the base and wait for the green light, my base has no light.
I also press sync on the camera flashes blue and then red.
nothing happens does not work, the app seems to be wrong or my base unit is different.
how to i sync the cameras
Press the sync button on the base quickly do not hold then one or two seconds later press the sync button on the camera
If it fails to sync open the battery door remove the battery and then replace it to reset the camera, wait about 30 seconds before you press the base sync button again
What LEDs are lit on the base and what color? Power and Internet must be green for anything to work properly. Did you add the base to your account prior to trying to sync the cameras?
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy927
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,082
						Videos233
						Vidéo2
						Warranty & Contracts2
