vmb 3000 base station shows internet connection (green light) but is not discoverable on any device
moya,
Consider a factory reset of the base station by pressing and holding the reset button until all LEDs flash amber.
Allow the device to come back online with a solid green power and internet LED and try again.
Be sure that the device you are using to set up for the first time is on the same network as the base station.
