Hi
I am the owner of several VMS3330 systems with cameras dependins on battery
this is really a burden (time and costs), good for retirees or jobless people
is it possible to upgrade my 7 cameras with the new battery system of Arlo pro?
or any alternative?
or an exchange program?
Philippe
There's no exchange/upgrade program for any of the cameras. You have to purchase new.
wonderful
philippe
But you can use rechargeable RCR123A batteries for the Arlo\s. Netgear recommends the Tenergy 3.7 V ones which may be easy or hard to get depending on where you live. (in Canada and US on amazon.com and amazon.ca)
For non US or CA customers , there are some alternative rechargeable products on the net (such s PPower)
regards
Philippe
ppower advertises 3000 mah @ 3.7v Seems way too high. so I'd be very wary.
Agreed. If the rated capacity is much above 650-700mAH, it's a bogus claim. Also, the cheap ones don't have the over- and under-voltage protection built-in that has caused some cameras to be damaged. I tossed (recycled) my cheap crap batteries a long time ago.
