why does my arlo keep timing out? I want 24/7 recording and it won't do that.
Arlo will not give 24/7 recording due to excessive use will drain the battery in a short time... max record is about 30 mins before an auto shut off for this reason.
For 24/7 records, you may need the Arlo Q camera with the cvr option
Thanks very much for your response!
Thank you for your response and help on this. I will try it.
