time between recordings
I have noticed that after a motion event and set record tiome has elapsed and consequent motion does not start process again. is there a reset time for that process,?
So if some one comes to door, the motion kicks off and recording starts (yes with the 3 second delay to start 😞 ). The event stops and person is still mvoing around my door. the motion event fails to start again.
I have many vids of a cat moving into a motion detect..stopping to eat and due to lack of movement while eating the recording stops at timed end... but the min she moves again the recording restarts for the same time pre-set amount..
If you motion sensor doesn't detect the person still there ,slowly move up the sensitivity slider a few percent at a time.
