i have both the old and new base stations....now that i bought 6 more cameras to add to the 4 i have....i can not upgrade to subscribe. there is nothing on the app and nothing on web access. I only get that i have a basic plan and no option, button, setting or otherwise to click on to upgrade my plan.
what is going on???
Which OS are you running?
On my Android app, I hit the 3 button stack at the top right and then click Settings
The first option under Account is Subscription. Hit that and it gives me the option to Upgrade Now. Do you not have that?
Similarly in the web access, Settings, Subscription. Here's a screenshot from my computer
Any of my Apple devices and Surface Pro W10 on web app doesn't have that 'upgrade button'. Have access this forum from my Surface to paste a photo....it's the same as yours just misssing THAT button!
Correction it says the following on that line in bold:
To make changes to your subscription, visit the web Arlo app
.... web Arlo app Also has no upgrade option! Link below has a snip of it.
The iOS Arlo app appears to be having all sorts of issues at the moment. I'm sure the engineers are working on fixing it but it might not be for a while 😕
For the web browser, I'm using Chrome on Win7. Not sure if that makes a difference.
If no luck, head to the bottom of the page and click Contact Support. Then open a live chat with a Netgear Agent. They should be able to help you in case there's an issue on their end
Subscription plans can not be purchased using the iOS Arlo mobile app. To purchase a subscription, visit https://arlo.netgear.com/ using the web client.
Same here this really sucks! I have 2 base stations 8 cameras, I just can't upgrade not in the android app not in IE not in Firefox and not in Chrome ridiculous it's like the first post discribes, solution as given by James C is worthless
Thx
