rotate/invert image does not work
New Arlo HD with base station. Just downloaded latest iPhone app. I click Rotate Image and a pop up at bottom says "Inverting Image" but nothing happens. Camera problem or app problem? Firmware 1.2.7730
Just worked for me. Did you remember to save?
button/toggle won't stay in the ON position so there's nothing to save. Pops back to OFF immediately. This is after iPhone app update. iPad still has older app and Rotate works on iPad. Sounds like new app to me. --cm
cmexal,
I have tested this using Android, iOS and Web client. On Android and web client there doesn't seem to be an issue but I am seeing the same behavior as you describe on iOS. I have escalated this information for further investigation.
Thank you,
My case with this problem is still open and has been re-created by one of their Netgear moderators. I was lucky and had installed the Arlo app on my iPad also and had NOT upgraded it to the latest release. My iPhone was updated to the latest release right before I tried Rotate. I was able to set Rotate from my iPad and then I could view the rotated image on my phone. Tech Support knows all of this. --cm
This issue is still being investigated. I will post an update as soon as I have more information.
Thank you,
