problems with onboarding using arlo app
  • 2966 Views
asdf12345
I'm trying to set up the Arlo Pro 4 XL kit that I bought. Doing that requires using the Argo app, which won't let me finish logging in.
I can access my account just fine via the web site (as evidenced by the fact that I can post this). When I try to log in with my phone, it says I need to set up a trusted device. If I choose to "trust" my phone, it errors out and says that method already exists. If I choose to use SMS for verification, it errors out and says that method already exists. There's no way to get past this step to actually set up the cameras that I bought.
How do I get logged in? I'm using the Arlo app on Android.
asdf12345
I had to uninstall the app, then reinstall it, then log in using the information from my interrupted prior sign-up. Then it worked. Not the smoothest process.
ShayneS
Hi @asdf12345
Are you still experiencing this issue?
asdf12345
ShayneS
Thanks for the update!
