  • 5 Replies
  • 3943 Views
tsav
Ok.... this camera, mounted to look at my driveway used to work nicely. I replaced the Batts and pointed it in a very slightly different direction, and now the damn thing records a bug a 50ft, but ignores a giant truck coming up my driveway>>>????
WTF ?
I have fooled around with the sensitivity and it still records when the wind blows but I just drove in the drive and not a peep....
ideas ????
thanks
5 REPLIES 5
Post a screenshot.
tsav
sorry..of what?...the view the camera has ?
Yes.
tsav
Here is the view from the cam. Be advised this camera USED to work flawlessly... I have done a remove/add device from the system... and it continues to not record or record very randomly....sensitivity is set at 82. Also... if i try to take a "snapshot" in settings it links up in about 5 seconds and captures an image without problem..... if I try to go "live" it won't connect.
Assuming most motion is across the FOV as your image implies, I'd open a case with support since you have have faulty hardware.
