I had not used this camera all summer as it triggers itself constantly and it was 25ft up in a tree. I moved it to ground level yesterday in hopes that it was the leaves on the tree triggering it. Nope. 46 recordings over the night. It is sitting inside a box as of 7am and continues its self triggering /recording. Ill let it drain itself.
It is all up to date. Current firmware, new batteries as of yesterday (basically dead now ). Cleaned front lenses and re synched etc. All the simple suggestions arlo throws at you.
Any ideas?
Any ideas?
The only other thing to try is to remove the camera from Settings, My Devices and resync it with fresh batteries. If that doesn't help, you have a bad camera and need to open a case using the Support link at the top here for a possible RMA.
