no picture
On the app on my phone, I do not see anything? Camera synced and all threee lights on base are green,
Camera does detect motion and is sending my phone alerts, but no picture on my ohone.
Start with reinstalling the app. If still broken, try using the browser. Let us know..
immyg,
Were you able to resolve this issue by reinstalling the app?
I am experiencing the same problem. My system was working with one camera. I added a second and all the web page would say is ...
We see you've synced a new camera.
Your service plan supports 5 cameras.
and start viewing your new camera right away.
If I'm good for 5 cameras, having only two should not require an upgrade. Now nothing works. All three lights are lit. The cameras are synced. But there is no feed picture any more on the computer or my phone.
I tried turning off and retarting. And I've tried resetting. Neither worked.
Blowrey,
The engineering team has identified and resolved this issue. Please let us know if you continue to experience this behavior.
Hi
I have the same issue, the second camera send alerts but recor no video and I am unable to watch live.
Biltonk,
We experienced some server issues during a short period of time last week. These issues have since been resolved. Are you still experiencing this behavior?
You say you reset and resynced - did you actually use the reset button or just the power switch? Regardless, try switching the cameras around temporarily - does the problem follow the camera or the position? If it's the position, it might be a poor connection between the camera and base.
Peterhengel,
You might also consider removing the camera entirely from the system by navigating to Settings > My devices > Select the affected camera > Remove Device. Power cycle the camera by opening and closing the battery compartment door and then go through the sync process. Please let us know if you continue to experience issues.
Martina2015,
Could you provide more detail surrounding the issue? When a camera has synced successfully to the base station, the camera LED (center LED on the base station) will show up solid green. Is this LED showing as solid green after you have synced a camera?
first thing is does the 'bad' camera allow live viewing??
If it does, I'd reset the camera by opening and closing the battery door, then remove the camera from the system ( under camera settings ) and then bring the camera back as new ( re-sync )
The wireless camera did not sync The third light on netgear box does not turn on?
Open and close the camera battery door. Press the sync button on the base briefly (<1 second) and, when the camera LED is blinking, press the sync button on the camera. The camera LED should blink slow blue until is syncs (may be many seconds) and then rapid blue when synced. An amber LED will light if it fails.
Have you opened a case with support? Hardware issues require that.
