no battery usage icon on app
I have just updated to the new android app update. Now I have no battery usage icon
What device and OS you running...
running OS 7 on S7 and see no issues
With that exit the app in SETTINGS and then log back in
Also first try and power down your phone and then turn back on
If above two don't fix , un-install and re-install the app
I have Nexus 6P with OS 7...Work fine on my iPad
I have 3 Camera and 1 is showing batt icon not the 2 other
Had a similar issue but the was related to Fire Fox in my option as other browsers didn't do it... Now thinking a bigger issue
Skoda,
I am able to see a battery icon across all clients for all battery operated cameras. Is the camera giving any error messages or is it behaving normally (recording, live streaming etc.)?
Skoda,
Consider reinstalling the mobile app on your Android device. Are you still seeing this issue?
Skoda,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
