  • 2 Replies
  • 12068 Views
kmk101
Yesterday I purchased an additional camera. Immediately after the blinking blue light showing it synced the light  blinked orange.  On the app and web portal it shows the camera is off line.  I have rebooted the base,  changed the batteries in the new camera,   and tried to sync it again (no lights at all now),  what else can I do ?
Thanks in advance,
Kelly
Toy1120
I'm having the same exact issue with my new camera.
ChristineT
Good morning KMK101,
It sounds like the firmware update (alternating blue and amber LED flashing) process may have gotten interrupted which has been known to cause the Arlo camera to get into a bad state. I recommend contacting our Support Team, they should be able to assist you further in recovering the camera.
Best Regards,
Christine
Arlo Team
____
Please click KUDOS or REPLY if you found this helpful.
