I can not connect to basestation. I have tryed via Iphone, Ipad and Imag. Iphone and Ipad via wireless. That dosnt work. It say that I have to connect to same network as the basestation. The Imag is connected via cable. I have a Internet router and from that into a switch. From the switch to Imag and basestation. I can read here that others had success via cableconnect But not here. And yes I have tryed to reset the basestation. Is here someone who have the same problem. The Instuctionbook on arlo.com and wiht the box is ekstemly por.
Please help. Its petty annoying to use so many hours on something that Arlo says takes 10 min.
What arfe the LEDs on the base showing? There should be 2 green ones - power and Internet. If the Internet one is not green, it has no Internet access to the servers, which is required.
If your trying to connect your devices to the actual base wifi system, it will not connect. ONLY the cameras can connect to the base units.
What is the next step if the internet light stays amber? I let it run for a half hour and it didn't turn green. I unplugged and ttried it twice.
SET UP; my computer & mobile phone cannot connect to the base station. internet & power LED are in Green. When I factory reset,. there is no amber lights no matter how long I press the reset & sync buttons..
Old reset procedure. These days use just teh reset button until the LEDs flash amber.
Where is the " teh reset button " ??
On the back of the base, next to the power switch.
