The ISP states that it sees the base station, yet it is not connecting. I have had this set up and added additional newer cameras since 2015. I have never had a problem. There was some kind of a power blip one morning and ever since, problems. Nothing I do works. Its not the cords, I switched cords with different device to make sure. I have tried resetting. I give up!
Are you doing a restart or a full factory reset?
Many times when a power blip happens, it's accross all your items...
So power OFF the modem, router, and base ...then Bring them back on in the same order ( give each one time to reboot )
If Still NG, then a reset of the base may be required as mentioned above
Thank you for your reply. I'll try all suggestions and report later.
Base Station back up and all cameras synced! Thank you support community for your feedback.
I had read multiple times that to reset and see amber lights I was supposed to hold both the sync and reset with a pointed object. But, when I finally re-read the link sent from above there was no mention of holding both, just the reset only. I saw the amber lights and was able to restart my system.
I'm so glad I finally posted and asked for help. Thank you! What a relief!
Well done and thanks for the feedback. It will help others who may have the same problem.
