The recording lag on outdoor Arlos makes these almost useless in many situations as the object triggering the recording is out of frame before the recording begins. Why doesn't Netgear develop a motion detection device to use with rules to trigger a camera to overcome the lag problem? I.e., why do I have to "waste" an expensive camera just to trigger another one? Coudn't Netgear develop/sell a motion detection device -- at a cheaper price than another camera -- that could be optimally located to trigger recording? Wouldn't this solve the lag issue and also improve the motion detection coverage as the device could be positioned for motion not viewing angle? I know Netgear would rather sell expensive cameras but this system is useless with this lag as subjects are often out of frame before the recording begins.
You might want to try searching on this topic. It's been discussed many times.
I have searched and have seen several threads re lag and setting up cameras to improve motion detection, etc. but have not found a thread re a triggering device (not using another camera) and rules to improve motion coverage and eliminating lag. None of the threads I see solve this problem and it does make the outdoor cameras somewhat useless in certain situations/locations as they do not begin recording fast enough to catch the object or person triggering the clip even if set up optimally. The multiple previoius threads seem to confirm that this is a problem that has not been solved. Am I missing something or are you just referring to these generic "lag" threads?
Post screenshots for suggestions.
