  • 4 Replies
  • 3527 Views
Hokallabird
Hi!
We would like to stream realtime video and put it on a webpage. This is for bird activity.
is it possible and what is the easy way for this? Any plugin to add account info and so on...
Thanx!!
Anders from Sweden
This wouldn't be a good fit for Arlo since streaming will wear the batteries down quickly and the system turns off streaming after 30 minutes anyways.  The new Q is powered so might be a better fit although it should be installed indoors unless you're really creative to protect it.
Hokallabird
It will not stream all time, only when someone klick "realtime" button and then for a while.
Some script possible?
I suppose it's possible but perhaps at the risk of security.  Someone posted a mechanism a while back (sorry, don't remember details) for automating the web page but any access via scripting uses login information which poses a bit of a security risk depending on your paranoia level.
Hokallabird
This is for animals recording = )
