  • 2987 Views
avets111
why did my camera go from 100 pics (outside)a day to 1220 pics in one day, oh and bye the way, there is absolutly no movement in any of those 1220 pics!!
Sounds like you have to reconsider your placement AND adjust the sense level
Check out the FAQs for info on both
sidartha
Since you stated that you have had it for over a year and it just happened, I doubt placement or sensitivity would have anything to do with a sudden change.
Most likely you are experiencing a bug that was recently found where the camera is being false-triggered for sounds even if audio is on or off. Netgear is working on a fix for it: https://community.netgear.com/t5/Arlo-Pro/Detecting-audio-though-audio-detection-is-NOT-on/m-p/12683...
Arlo Pro hasn't been available for a full year yet, it would seem the original post is referring to the original Arlo Wire-free cameras (which do not have audio).
Consider rebooting your base station along with the camera (open and close the battery compartment door).
Are you still seeing the same behavior?
