installation
  • 2 Replies
  • 3101 Views
joeasantos
I am considering placing a camera on a lampost in front of my house. What Arlo model would you recommend that would be easy to install the device on the lamp post?
What is the lamp post made of...around here, they are aluminum and the magenet won't stick so you'll had to fiq a way to attach.
If outside ,then it has to be an Arlo or an Arlo Pro...think the Pro is a better choice ( tho is does use rechargeable bettery pack )
Hula_Rock
Prodigy Prodigy
Prodigy
and is the lamp post your property?  dont think the city would be too keen on you attaching it to its property.  Friend of mine has a Arlo Camera mounted to his lamp post on his farm.  He used a security camera mount and deck screws.....
