Hi
Pressing the sync touch for more than 2 seconds does not activate the green light...any idea ?
Thanx for your help
You should not be pressing the SYNVC button for 2 secs...it's really a QUICK PUSH ONLY
( in the older models not sure if still , holding the sync button to long put the base into some sort of unusable programming mode for a min or two )
You were right !!
it works perfectly now...( but I swear the + 2 secs push.is requested in the quicksetup guide !!??)
Thank you very much for your precious help, TomMac !
