  • 2 Replies
  • 2408 Views
ant
Mentor
Mentor
I had to enter the old account password manually. 😞
What happened? Thank you in advance. 🙂
brh
@ant
I turned mine off a long time ago as they only give you one chance to get it right then they make you physically sign in. If your finger is just slightly off center of the button it will not take and it will force you to log in manually.
Brian
ant
Mentor
Mentor
@brhwrote:
@ant
Brian
Well, it used to remember the password too. 😕
