iOS Mobile App
  • 8 Replies
  • 2025 Views
RaylanC
Regarding the new mobile app, how do I return to seeing my devices as the default opening screen rather than 'Dashboard'?
Best answers
  • StephenB
    @RaylanC wrote:
    I suppose I will not have a choice but I will only be duplicating the Devices tab, unless I'm missing something.
    You can only change the mode from the dashboard, so there is unique functionality there.
  • ShayneS
    @RaylanC
    The dashboard is fairly customizable. You can add your devices in any order with various size thumbnails etc.
8 REPLIES 8
It may depend on the app version for the OS but Android works fine if you leave the app while viewing Devices - it will reopen there later.
RaylanC
iOS 18.3.1
Arlo app:  5.6.0 (9095)
Only opens on Dashboard if I leave the app from Devices screen.
ShayneS
@RaylanC Are you soft closing the Arlo app or hard closing removing completely from your background dock.
When I soft close the app it will return to the devices screen after selecting the tab initially.
RaylanC
Meaning you keep the app running in the background. Yes?
I close it.  Reentering brings up the dashboard which I have no use for.  I prefer the prior app version.
ShayneS
@RaylanC
Have you considered adding widgets for each of your cameras to the dashboard?  Then it is similar to the the devices screen.
RaylanC
