how can i adjust motion detection from distance more than 5-6 feet?
  • 1 Reply
  • 5175 Views
SSH
My Arlo cameras can't detect motions from far, more than 5-6 feet away from cameras.
Kindly help me the ways how should i adjust. i tried motion detection test with almost all levels, incresed by 5 each at a time.
Thanks.
Sound like you may be adjusting the wrong level... Motion detect level is in the MODE not settings ( thoses are for testing purposes )
Go to MODE and the mode you arm with > pick base then camera
Use > to EDIT
On EDIT MODE page , click > again at the MOTION IS DETECTED
Adjust the slider bar...80% is normal settings, higher is more sensitive
Use the BACK at top left of page , SAVE is on bottom of previous page
