  • 4 Replies
  • 18592 Views
  • 3 Likes
mendedbones
What is the current version of Firmware for the camera. I purchased my system yesterday (4/7/15) and the version is 1.1.1733 which seems older than what most people in the community have reported as 1.1.2074. I have tried to update it by removing the batteries and ensuring that the slider on "Auto Update" under settings is green but nothing has happened. Thanks for your response.
The current camera sw is 1.2.2412
Make sure auto update is on, (since you tried opening the doors ) reset the base by the power button...see if that will start the auto update after it reboots.
mendedbones
Thanks. Your solution worked and updated the camera
Ariella
How do I select automatic firmware update
Schorschi
Prodigy
Prodigy
This is an old thread. The information is outdated. Auto-update is the default. It's no longer user-configurable.
