Répondre
Statistiques de discussion
  • 1 réponse
  • 1067 visites
  • 0 compliments
  • 2 en conversation
2a
Bonjour, j’ai l’Arlo Pro 5 et je ne sais pas comment activer uniquement la détection “humain” afin que la caméra ne se déclenche pas à chaque passage d’un chat, chien ou oiseaux. Comment dois-je faire ?Merci
1 RÉPONSE 1
You need a subscription to enable the smart notifications.  Instructions are here:
I also suggest looking at your motion detection threshold. Lowering it will reduce detecting small animals.
Use the test described here:
Move around in the region of interest when running the test, and find the lowest threshold that detects you reliably.  Set the actual threshold just a bit higher than the one you find in the test.
