connecting netgear hub to huawei mifi
  • 1 Reply
  • 2582 Views
Callan
can I connect the netgear server to the huawei e 5151
If it has an Ethernet port or you use a WiFi extender that has one this should work.  However, there's so many combinations out there it's impossible to know for sure.  You can always but a system from a store that lets you return it if there are problems.
