connect base of arlo to my tv
is there anyway i can set the the base to connect base of arlo to my tv so i can use it this way
Sorry, it's not clear what you want to do. Do you want to use your TV instead of a computer or mobile device or are you trying to somehow connect the base directly to the TV?
