Im experimented with 4 cameras and want to tiger all others cameras to satrt recording when detecting from one off them.
F. e. when A detect motion , I want BCD to start automaticly for att list 5 minutes aven if nothing detect on them.
Same for BCD and that make a very long rule .
I wish a standard button on rules to do that
You can only record for a maximum of 2 minutes (120 seconds)
To get the recording you want, create a custom mode
In that mode make rules:
Camera A motion triggers camera A to record
Camera A motion triggers camrea B to record
A > C
A > D
B >A
B > B.... so on and so forth. You'll end up with 16 rules
Hi Steve
thanks, this is exactly what I did.
But my suggestion was if the NG could fix such an option infuture version ?
I think that if ou have 4 or 5 cameras , you will wish this
Excuse my English
Yep. Pop it in the ideas exchange section for the engineers and software people to consider. I have some nested rules where cameras trigger other cameras but I don't have a need for one camera to trigger all other cameras. I have 12 cameras
With this rule , you don t need 5s before detecting ;))
