  • 2 Replies
  • 3667 Views
boblookeat
Hi
I plan to change the Arlo Hub with the one with alarm included (VMC4000) and adding new Arlo Pro cameras. Can i use the Arlo camera that I currently have and regsiter them to the mew Arlo hub?
brh
@boblookeat
Yes, I have done that. First you will need to remove the camera from the original base and add it to the new base. Or you could have two base units. It is up to you. The original Wire free, pro and pro2 cameras will work with either base and you can have as many base stations as you need.
Brian
As a PS to above... mutli bases is the only real way to expand coverage area.
Slight downside is each base will be separate and have to be armed on it's own.
( I find this better as I split my cam bases into front/back cameras and run different schedules /etc on each , YMMV )
