I have two cameras, just trying to set up. On Syncing first camera, worked fine. Second camera pressed sync on base station nothing happened( light is a solid green). Could see live first camera, nothing on second. When trying to sink second camera about 10 times, light blinks orange at end of procedure.
When I move either camera I get a notification that Motion is detected.
What am I doing wrong?
If you're getting notifications when moving either camera, they must be synced to the base. Try power cycling the base and open and close both battery doors. Does everything come up OK or not?
Colima,
Did power cycling the base as suggested above resolve the issue? Please let us know.
