cannot change wifi channel
  • 2 Replies
  • 9206 Views
J088E
Hey
Is there a possibility to change the wifi channel?
I want to give it a fixed channel because it takes sometimes the same channel as my own wifi channel and this leads to no internet connection.
Many thanks already
Also, if you want a channel for Arlo thats far from your router there's another way.
1) set your router to the wanted channel
2) reset Arlo base with it near the router ( it will pick the same channel to avoid interference )
3) reset  your router back to the original channel
( as you should be able to access/change yr router channel but no access into the Arlo base )
The only way to change channels on the base station is to move it further from the router.  20 feet is often suggested as a good distance.
