can the ARLO solar panel be retro-fitted to the ARLO camera?]
Is there any way that the ARLO VMA4600 solar panel can be used with the original ARLO cameras?. As the ARLO has no USB plug, where could you get a workable connection at the battery contact points?
No, it will not work with the original Arlo camera
Not to mention, the voltage requirements are slightly different.
Tho for rechargable this will work ;
