camera shows 10 videos but only shows one of them in the library
I have two cameras. Both of them show a number of videos in the little green box on the left but only posts one of them in the library. How do I fix this?
I had the same problem some time ago which was cleared up. Apparently something has happened again or it wasn't a systemwide fix some you're the second one to post today of this problem. I contacted support directly and they fixed it in short order.
I'm having the same problen with the videos not posting. How do I contact support directly? I'm lost on this web page... Thanks for your help
Click on Support at the top right of this page and then Contact Support under Helpful Links, again at the top right of the page.
Or click on this:
