One of my cameras goes offline. When I bring it next to the base I it goes back online. I put it back in its place and after a while it goes back offline. The camera is close to the base (6feet) without any unobstructing walls. The other camera is farther away and does not ahve that problem. Any suggestions?
Try and swap the two cameras locations...to see if the problem follows the camera.
If the issue continues, I'd contact Netgear Support for a resolution.
