arlo can i adjust thre sensitivity for the cameras?
  • 4305 Views
  • 2 Likes
arlo22
can i adjust thre sensitivity for the cameras? if so HOW THANK YOU..
yes
To change sense level;
Click on MODE
Click on BASE and modes will appear in right side column
Click on the MODE you want to edit, use ">" to edit same
you should now see the cameras, pick the one you want and hit EDIT
Drop down to MOTION is detected and hit edit again
The sense level slider is there... when you back out ( go BACK one page ) SAVE at bottom of the previous page
yes
Click on MODE
Elcaminokid
Which increases the sensativity, Higher or lower number?  I have unit that will turn on in a closed room during the night with no action showing in the recording but will miss the activity during the day that I want.
Higher number ( to right ) is higher sense... if the cam is going off facing a wall, maybe you should contact Netgear Support.
BTW, Location and placement is critical to capture what you want.
