arlo cameras
  • 2 Replies
  • 3177 Views
craig1234
does anyone no if u can hook up more then 5 cameras to one base
Schorschi
Prodigy
Prodigy
You can. But then you must upgrade your subscription plan to at least Premier, which is good for up to 10 cameras. The Elite plan will allow you to connect up to 15 cameras.
Be aware though that per base station the maximum number of concurrent video streams is five. So, one base station may not provide you with sufficient protection in case of a ninja attack or the zombie apocalypse when you're being attacked from all sides at the same time.
craig1234
ok thanks but i don t feel like thats fare because the d*** thing cost alot already
