alro wifi not recoding motion
Have set up 2 cameras on the arlo wifi system. Get notifications when motion is detected. Can also record manually while in live mode. When motion is detected it will not recorded. Been through the mode numerous times and its set to record 20 seconds. Obviously this is the main reason for getting this system. Any ideas before i give up and send them back? People have mentioned a green running man. Mine is grey and turn orange when motion is detected. Mever been able to get it to go green.
Under modes try setting the radio button to use armed. If its recording when motion is detected (will be the 20 sec default) then something probably wrong with the rule you're using
