  • 6 Replies
  • 7412 Views
JMS11
By adjusting the audio level, does that change the audio detection sensitivity level as well? I would like the speaker volume to work, but would like to turn the audio sensitvity down for detection way low to avoid unwanted alerts for noises.
Have you read the FAQs as I suggested earlier? All details are in there.
Volume is set in Settings, My Devices, your camera, AUdio Settings.
Sensitivity is set in the Mode tab, selecting your base and editing your modes and setting the sensitivity in the audio section. Be sure to save changes.
6 REPLIES 6
You need to edit or create modes. Read the FAQs here for full details. Basically, use the Mode tab, select your base, and edit the Armed mode or create your own custom modes. All settings are in there.
JMS11
I understand that you have to change each mode for each camera. But does adjusting the audio level change only the volume, or does it also change the audio detection levels? I would like to keep the audio levels up but decrease the audio detection levels.
Audio volume and sensitivity are separate functions that don't interact. Adjust each one separately as you desire.
JMS11
Thanks. So is the Audio adjustment in the pencil controls for the camera the sensitivity and the volume is elsewhere? Where is the volume for loudness if the pencil control is sensitivity?
JMS11
Thanks! That worked.
It is hard to find the link for the FAQ
