I recently had an outside wiring problem that shut down my router. ATT fixed the problem but now all activity (video clips) show the wrong date & time (shows at approx 16+ hrs in the future). How can this be fixed ?
P.S. My Time Zone is set correctly
Usu, a power off then on will fix time issues...
also you can temp change your time zone and then change back
under settings/base unit
The temp change of time zone worked !
