The first problem I see, is, not enough information.. What Netgear product doies your phone not connect to?
Is this an R7000 - AC1900?
Not sure if you can actually connect a phone to an Arlo Base Station @ElaineM can you have a look at this please?
Kiramaksim, netwrks
It is not possible to connect any device other than Arlo Wire-Free cameras directly to the Arlo base station (VMB3000).
It sounds like however, the customer is trying to access their existing Arlo account from their mobile device. You should be able to use the same login information to log in to your Arlo account via the mobile app. Are you able to login from a web browser?
Are you getting an error message when attempting to login? At what point are you experiencing the issue?
