Thinking of buying an Arlo Pro system. I need motion detection, and had planned to get separate detectors. Question is, would an Arlo on an Arlo Pro hub integrate with a Wink2 hub? Or, do I need the original Arlo hub as well?
You can use the Arlo or Arlo PRO on either base, doesn't mattter
There is no integration of Arlo Pro with Wink, yet.
