Will these cameras work?
  • 1 Reply
  • 2664 Views
Ed-R
We purchased the Arlo Arlo Smart Home HD Wirelss IP Security Camera 2-Pack which comes with a router at Costco.  We want to get additional cameras, and am wondering if the Arlos Q HD 1080p Wi-Fi Monitoring Camera 2-Pack, also sold at Costco, are compatable.  Does anyone have a recommendatin where to buy, that is not Best Buy (very expensive)?
Arlo and Arlo Pro cameras will work with either base unit ( arlo base or pro base )
The Q cameras are compatable and will appear in the same app/web access BUT it works a bit different than the Arlo models
The Q camera hooks directly into your home wifi network, while the Arlo / Arlo Pro link into only the base units ( that hook via etherent cable to your router )
Also, when you go to arm the system you must Arm the Arlo/Pro units and then the Q ( as they appear in the same program but act as separate systems )
As A PS; Arlo  / Pro can go outside while the Q is indoor rated only
At costco are about the best prices you'll get
