I have a new Arlo system VMS3330. The system is for my cabin, where I have no router, only my Verizon hotspot.
I saw a Netgear docking cradle station that holds a hotspot....DC113A. Is there an option like this that would allow me to run my Arlo off a Verizon hotspot somehow?
Thanks!
I can't speak for that specific cradle but if the hotspot has an Ethernet port, it should work. If it doesn't have a port, use of a WiFi extender with a port should be sufficient. In either case, your upload speed should average >1Mbs as tested by speedtest.net.
You may be interested in the new Arlo Go cameras which don't require a base and use ATT cell service (Verizon is said to be coming soon). In addition, the Q cameras, which are rated only for indoors, simply use your WiFi so no need for a base.
Of course, your data plan could be an issue, depending on how much recording and live view you use.
You can run an Arlo base from a hotspot if the unit has an etherent port.
Just remember that viewing and recording use aprox 1Mb of data thruput for each 10sec clip ( best video ) so if used properly , you can keep the total data amount down if needed
