Will a weak wifi signal degrade arlo live stream functions?
  • 2 Replies
  • 9340 Views
fivestar1
My cameras will live stream only a minute or two.  Then they stop streaming and the play button appears.  This happens with motion on or off.
I have the base station connected to the usb port on a range extender, which is also where I synced the cameras with the base.   I get a wifi signal and connect cameras up to 250' or more from the range extender.
Would I get better results if I connect the base station to the physical router instead of the extender?
My location is surrounded by metal buildings.
Thanks for your comments.
JPC
Prodigy
Prodigy
It would help maximize throughput..
Landon5
I originally had base station directly to router and one camera was always weak.. I moved station to a range extender/accesspoint and plugged it into it which allowed the signal to be stronger.. I read on other prior chats that the signal only works from base station and only way to increase weak camera is having base station closer which is true.
