Wifi update VMB3000
  • 1 Reply
  • 2861 Views
drillnpick
HI, IVE JUST CHANGED MY ROUTER WITH MY INTERNET COMPANY AND NOW NONE OF MY CAMERAS ARE CONNECTED TO MY BASE STATION.  HOW DO I GO INTO MY ACCOUNT AND CHANGE THE INTERNET INFO I NEED TO CHANGE?  I CANNOT FIND ANYTHING THAT LETS ME CHANGE MY SSID
Usually nothing needs to be done. The base needs to be connected via Ethernet to your router. There's nothing about your WiFi that needs to be done since these systems don't use it. The WiFi used between the base and cameras can't be accessed. What are the LEDs on your base showing? Should be 3 green ones - power, Internet and camera. If the router is owned by the ISP you'll need to contact them to open ports 80, 123 and 443 to Arlo.netgear.com.
