"It Depends." (TM) 😄
Using the browser, it goes to wherever the default download location is. On a computer, you can check the browser settings to see where it goes which will vary according to OS. With the Android app, the default is /sdcard/Downloads which is easily found using a file manager or running Downloads from the apps menu. No idea on iOS.
