  • 2 Replies
  • 1207 Views
Lindaeverett
What rechargeable battery is good for VMC3030 camera? I can not find the recommended Tenergy Li-Ion RCR123A 3.7V 650mAh rechargeable battery.
https://power.tenergy.com/amp/batteries/rechargeable/cr123a-16340/
There are 12 and 24 packs on Amazon (pricey if you don't need that many).
Tenergy says the 750mAh version also works with Arlo.
As to 123 rechargeable battery, just make sure they are 3.7v Li-ion around 700mahr.
( you basically can not fit more than 750 mahr in that 123 sized package...so if you see 1000mahr, it's prob not true )
