  • 4 Replies
  • 11058 Views
PaulQ_AZ
Do you know what name the Arlo base station uses in the list of connected devices your router lists with assigned UP addresses?
Is it "Azure Wave Technologies"? I don't see anything obvious like "Arlo" or "Netgear."
Thanks!
PaulQ_AZ
I'll post this here too in case anyone else is having the problem...
Yeah.... I thought that would be the case but I don't see anything "Netgear" on my IP list. I just now thought to look at the MAC addresses. I found it. It's under "VMB..." which just so happens to be the model number of the base station. Doh!
It should show up as netgear something..
Mine is Netegear_VBM_ xxxxxxxxxxx
PaulQ_AZ
I also see mine as VMBxxxx on my router.  However, using a WiFi analyzer shows a NTGR_VMB_xxxx so it varies according to exactly what you're looking at.
Yes... glad you found it... ( btw, slip of fingers above, as it is VMB not VBM )
The ssid is usu clearly visible and show as netgear one way or the other ( mac )
