Hi new user here have the H11 hardware version of the above camera, I am more than happy with the image quality but was wondering what the best re chargable battery pack option is I have 3 cameras. Many thanks
UK can be a tough one to get rechargeables for....
but if you search , there's some that are available to you there.
Just make sure of a few things;
1)you need 3.7 v li-ion in a 123 or 16340 format ( some 16340's can vary in size ( allowed) so check compared to 123 cells)
2) no quality cell will be rated at more than about 700mahr ( just can't be done ) so only buy NAMED brands of qualtiy companies ( no ebay crap ) with a overcharge /over drain protection circuit built in
3) a quality charger designed for these cells.
Of course , these cells are not approved by Netgear, so that way your on your own
ps copied from old thread; you can search the old ones too
Re: Buying rechargeable Battery and Charger by Tenergy Belgium (or Europe)
I'm now testing those batteries:
- https://www.batterijeshop.com/NL/EagleTac-16340-750mAh
So far, so good (1 week up and still plenty of power left).
I did buy this charger:
Works very well.
Maybe this might help users in Europe who can't order by Amazon?
Stijn
If you have the Arlo, it uses 4-123 cells.... Netgear sells a rechargeable set of cells and a charger ( approved by them )
https://www.arlo.com/en-us/products/arlo/tenergy_rechargeable_battery_charger.aspx
Thanks but they dont appear on the UK site Grrr!
Works very well.
Stijn
Thank you
